Banjo Bolt Torque Question
Old Feb 17, 2006 | 09:47 PM
folex187's Avatar
Default Banjo Bolt Torque Question
When installing my oil banjo bolts today I had a differing reading from my two torque wrenches by 5ft lb's. I torqued all of the bolts down using a guage type torque wrench and stopped at 12ft lb's as indicated in the service manual (The manual states that you must be precise with this).
After finishing the fourth bolt I went over everything with my click style wrench and found that each bolt went about another 1/2-1 turn before a click. I then checked each bolt over with my guage type and there was 0 movement at 17ft lb..
So, I went with the click style as it was a snap-on tool and I felt it was probably the most accurate.
If I am wrong and they actually all did go to 17ft lb will this cause any damage?
Old Feb 18, 2006 | 03:09 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
17 ft lbs will crush the oil jet itself and affect it's flow.
I would double check where you have the click-type wrench set at.
If you torque a bolt to 12 lbs, then wait a second, it will take more than that to make it move again.
Old Feb 18, 2006 | 09:12 AM
folex187's Avatar
Well, that's not good. The click style was definitely set at 12. I did a visual on everything and did not notice any bowing/extruding of the sides of the jets. Would I have been able to see it?
Old Feb 19, 2006 | 07:30 AM
RedY2KS2k's Avatar
What are the torque ranges of the two wrenches? i.e. 10-250 ft/lb, or whatever.
Old Feb 19, 2006 | 09:36 PM
9kFever's Avatar
you officially do have bad luck =)
Good luck man
s2000maniac
Mar 28, 2013 05:52 AM
bullet1123
Nov 15, 2005 08:11 PM
scrawny
Sep 7, 2004 08:51 PM
schwett
Jan 25, 2004 10:39 AM
rev_addict
Sep 11, 2002 10:38 AM
