Barely driven - help
Old Dec 17, 2009 | 09:32 PM
ROTFLMAO's Avatar
Default Barely driven - help
Hi,
I know that barely driving the car is bad for it. Right now I usually drive it once every two weeks but someone told me that is not enough as the oil from the engine will be all at the pan at that time. So my question, if in addition to driving her once every two weeks, let's say I start her up (idle not drive) every 3 or so days, will that alleviate the issue? Any tips or advice you all can give me?
Yes I barely drive my car, but when I do drive, I enjoy it... A LOT. Thus, I am having second thoughts every time I want to sell her. However, if I can't find a solution to this, I'd rather sell her...
Old Dec 17, 2009 | 09:55 PM
RickIsYoDaddy's Avatar
that should allevate any issues with oil settling at the bottom, but so would taking it out more often
Old Dec 17, 2009 | 11:21 PM
ROTFLMAO's Avatar
When I drive the car, I drive it for fun. I usually don't have time to do that though. How long should I let it idle for?
Old Dec 17, 2009 | 11:58 PM
GTS Jeff's Avatar
Does your car look, sound, feel, and drive totally fine? If so, there's nothing wrong with your car. What you're doing here is conjuring up a problem that doesn't exist.
But if it makes you feel better to go out and idle your car every couple days for no reason, go right ahead. If this imaginary problem is stressing you out, please do sell the car to someone who will enjoy it more.
BTW. My car sits undriven for 4 months straight every winter. It's fine. And then my winter car sits undriven for 8 months straight every summer. It's also fine.
Old Dec 18, 2009 | 12:05 AM
chViETnk's Avatar
my car had 15k miles when i bought it in feb 09,MY2000 and at 21k miles now, it drives fine.
Old Dec 18, 2009 | 03:55 AM
SpitfireS's Avatar
ROTFLMAO Posted on Dec 18 2009, 08:32 AM
So?
Once you stop a warm engine the oil will drain back into the sump.
After, lets say, 3-4 hours, 99% of the oil that can drain will have drained.
Some oil will stay up on the head, no matter how long you wait.
So there is little to no difference between a 3-4 hours drain or 2 weeks drain period when it comes to oil level.
That is the LAST thing you want to do.
Idling a cold engine to operating temp is VERY BAD!
#1 - you get lots of unburned fuel from running extra rich (cold engine), that will wash the oil of the cilinder walls, that is BAD.
#2 - you will get lots of harmfull chemicals from all the unburned fuel, doing damage to the cilinder walls and pistons and they will get into the oil, breaking it down causing corrosion in the rest of the engine, also BAD.
#3 - idling without driving is bad for the transmission, the trans oil pump does not pump (you're not driving) so the trans is only lubricated by splashing some thick oil around.
#4 - it takes a very long time to get the whole engine & trans warm, it will take a lot of fuel = create pollution.
Drive it every 2 weeks for at least half an hour or so, get the oil warm, let the fuel & moisture in it evaporate and you're fine.
Old Dec 18, 2009 | 06:12 AM
ROTFLMAO's Avatar
So?
Thank you. Not only for explaining things very well, but also taking the time to post this VERY helpful reply. I sincerely appreciate it.
Old Dec 18, 2009 | 06:52 AM
irv_usc's Avatar
So?
Pretty much exactly what I was going to post.
another thing I wanted to add is that if you just idle the car, the catalytic converter will never get hot enough to properly operate. You will likely end up with a rusty exhaust system due to water collecting in the piping.
Old Dec 18, 2009 | 07:03 AM
Slick2K's Avatar
I bought my '05 new in Jan of '06. It has 7,400 miles on it so far. It sits a lot! No problems what so ever.
Old Dec 18, 2009 | 07:19 AM
dales2000's Avatar
So?
i never knew that you are not suppose to let ur car warm up
