Battery problem
Old Nov 30, 2014 | 07:41 AM
jean-roch's Avatar
Default Battery problem
I constantly need to replace my battery, i have the most powerful Delco battery and it last between 6 monts to 2 year, i dont have current drain, my alternator was in specs but always have the same problem, my oem battery last 5 years, i have a type d amplifier and use the car all days all years, any solution?
Old Nov 30, 2014 | 09:41 AM
Gotpepsi's Avatar
That's not that bad actually. I been using the Duralast Gold. Its been good.
Old Nov 30, 2014 | 01:59 PM
windhund116's Avatar
Originally Posted by jean-roch
I constantly need to replace my battery, i have the most powerful Delco battery and it last between 6 months to 2 year, i dont have current drain, my alternator was in specs but always have the same problem, my oem battery last 5 years, i have a type d amplifier and use the car all days all years, any solution?
This seems a bit too soon (and $$$). Maybe, a parasitic drain on the battery?
https://www.youtube.com/watch?v=n5FJ...tion_891469363
http://www.youtube.com/watch?v=n5FJD...tion_891469363
Old Nov 30, 2014 | 02:18 PM
Gotpepsi's Avatar
Six months to two years is a huge difference. If the OP said that 2 car batteries drained in 6 months than we could say there is a problem. However, the OP also said that he's running an amplifier in the car, this is most likely paired with a subwoofer. If so, perhaps the OP abuses the battery more than other s2000 owners by bumping music while the car is off. This could make batteries die faster.
Old Nov 30, 2014 | 02:30 PM
Even two years, would get kinda $$$. Maybe he needs a bigger alternator.
Old Dec 1, 2014 | 07:23 AM
matthugie's Avatar
Or something in the sound system isn't hooked up properly and causing a parasitic drain. For instance, if the amp was hooked up to the constant +12v instead of the switched +12v it could be drawing current while the car is off, greatly reducing battery life.
Old Dec 1, 2014 | 10:52 AM
hirev's Avatar
Mine last about 5 years,these are not large batteries. I have a trickle charager for it as I only do about 5000 or less a year now.
Triple-H
92
Apr 13, 2011 11:06 AM
m4rcs2000
Mar 23, 2009 01:34 PM
CostaK
May 8, 2004 05:45 PM
CoralDoc
Jun 25, 2002 12:33 PM
