Battery Relocating
Old May 2, 2024 | 02:17 PM
medmunds151's Avatar
Default Battery Relocating
I have recently moved my battery to the trunk and upgraded to a Red Top Optima Brand. I originally installed a 60amp circuit breaker but the car seemed to struggle with the inital crank, it did start but it sounded weak. The optima battery is brand new and has a 12.3v charge showing on the multimeter. I connected the battery to the circuit breaker then to a splitter. I used 8 guage wires from the splitter to my kicker amp, then two 8 guage wires back to the wires that were originally connected to the battery under the hood.
Question is: should I use a higher amp circuit breaker, or/and should I use a larger guage wire? I guess since I've added the additional 10ft of wire to the trunk it might need more flow with a larger guage wire?
I'm still learning so any help would be tremendous.
Attached Thumbnails Battery Relocating-screenshot_20240502_181245_amazon-shopping.jpg   Battery Relocating-screenshot_20240502_181307_amazon-shopping.jpg   Battery Relocating-20240502_114552.jpg
Old May 2, 2024 | 07:38 PM
spider2k's Avatar
Active Streak: 30 Days
8ga is nowhere near large enough for the amount of current the starter draws.
Old May 2, 2024 | 08:07 PM
That is what I was afraid of. What would you recommend?
Matts2k87
Jan 25, 2016 10:13 AM
blink962
May 15, 2015 05:25 AM
macprotege5
Feb 28, 2007 09:27 AM
cshamash
Mar 5, 2006 12:46 PM
DaPutster
Jun 27, 2005 03:13 PM
