bent headlight support?
Old May 5, 2011 | 06:33 PM
hellspare's Avatar
Default bent headlight support?
Hey guys, unfortunately I had an accident recently, and I bent my right headlight support. As a result, even a new fender and bumper won't line up with the headlight correctly, even the mounting threads for the fender are bent. Basically when I match the fender and the front bumper the headlight is pushed in a little. Which parts do I need to replace?
My question is, can I just replace the headlight SUPPORT, and not the whole headlight assembly? The headlight works perfectly fine. If yes, how much would it cost and where can I order it?
Thanks, frank.
Old May 5, 2011 | 09:24 PM
DFWs2k's Avatar
what color is your car and where are you located, i have mine that i am not using due to intercooler pipes
yes you can just order the headlight supports on their own
Old May 5, 2011 | 10:53 PM
hellspare's Avatar
car's berlina and im in norcal, cupertino area to be exact.
Why does color matter though?
Just to be clear, I need the brackets that the fender also mounts to. I hope I'm calling it the right thing.
S2kmonkey
Mar 29, 2012 08:47 PM
hellspare
May 10, 2011 04:30 PM
drhess06259
Nov 15, 2010 10:41 AM
immaViLLaiN
Dec 28, 2006 09:06 AM
S2FiONE
Nov 7, 2005 12:36 PM
