Best Transmission Fluid
Old Oct 25, 2001 | 03:44 AM
sixtynine's Avatar
Default Best Transmission Fluid
I'm going to change the stock transmission fluid, which is the best oil I can get that could help to solve the 1-2/2-3 grind problem?
Thanks,
Sixtynine
Old Oct 25, 2001 | 05:56 AM
Takashi KazuMori's Avatar
I don't know if it will stop the grinding, my 01 VGS gearbox does not have such problems in the first place. However after I changed my transmission fluid to "Castrol Syntrans 75W85" if I can recap ... 1 and 3/4 litres the gearbox shifts better than ever. Thanks to Naishou for this one, I'm basically a full Castrol supporter.
Old Oct 25, 2001 | 06:48 AM
cdelena's Avatar
Thanks,
Sixtynine
A different lubricant will not change the grind.. it is caused by either a clutch problem or transmission problem. IMO the Honda transmission lube is the right one to use in this box.. I have had disappointing results with the others.
Old Oct 25, 2001 | 07:00 AM
RT's Avatar
RT
I agree 1 million percent! I'm back to stock Honda after several disappointing experiments, don't stray on this one.
Old Oct 25, 2001 | 07:10 AM
sixtynine's Avatar
Sorry guys I used the word "grind" instead of the word "notch" (it's my english teacher fault ), I know that the grind will not change, also because I had that problem only few times, but I mean some oil that could help to solve the notching.
Sixtynine
Old Oct 25, 2001 | 07:48 AM
bayareas2k1's Avatar
my clutch doent grind in anygear, however from 2-3 it feels a bit notchy. is this normal? if i depress the clutch petal for about 1 second before i go from 2-3, the notch is not there, only when i depress the clutch petal and go 2-3 it feels notchy. is this normal?
Old Oct 25, 2001 | 04:39 PM
naishou's Avatar
Like Takashi I found the Castrol Syntrans smoothed out my gearshift quite significantly. This is compared with new Honda fluid, not old stuff. It's still not perfect though.
Old Oct 25, 2001 | 04:54 PM
Sev's Avatar
Sev
Just because an oil lubricates better doesn't mean you woudl want it in your tranny. An oil that lubricates too good will prevent the syncros from doing their job as they will be unable to get a quick and good grip on the gears, you will have premature wear on your gears.
Stick to what Honda reccomends in this case.
Old Oct 25, 2001 | 05:08 PM
johnyboy32's Avatar
RT,
What other tranny fluids have you tried? Red Line?
Old Oct 25, 2001 | 05:52 PM
bgrubin's Avatar
[QUOTE]Originally posted by johnyboy32
[B]RT,
