BIG Speedometer & Odometer Error
Old May 14, 2005 | 12:22 PM
Cristiano's Avatar
Smile BIG Speedometer & Odometer Error
Gentlemen,
I hope I am in the correct forumn. I used the Search function; but, it is either disabled, or, the keywords "speedometer" and "odometer" were not archived. In any case, I was out "breaking in" my 2005 S2.2K, today. When I came to spot in the road, at a stop sign, I pushed the "Trip B" tab to reset it to 0.0. At first, I thought I had not pushed it hard enough, so, I pushed again to reset to "Trip B" and then proceded to push harder. This time, the tripmeter went to 0.0; however, the odometer, which had been reading somewhere near 340, changed to 586. I switched to "Trip A," and saw that it too had advanced to 586.2!
Furthermore, I found out that the speedometer was now (guesstimating) reading about 24 to 33 MPH over the original readings. I know this because I was using the recommended shift point (e.g. 15 MPH = 3500 rpm, 25 MPH = 4000 rpm, etc.) I only hope that the tachometer was accurate.
I drove straight to the dealership from which I had purchased the S2.2K. I will be unable to address the problem until Wednesday, my afternoon off. Does anyone know what the problem could be?
ric
Romans 8: 31
Old May 14, 2005 | 12:32 PM
s2k_9000rpm's Avatar
are you serious???
Old May 14, 2005 | 12:37 PM
xviper's Avatar
I'll bet you hit the button that put you into KILOMETERS.
Hopefully, your dealer won't be an ass about it and charge you an hour's labour just to push the button to turn if back to MILES.
Old May 14, 2005 | 01:24 PM
CrazyPhuD's Avatar
My first thought too....hahahah
BTW 340 * 1.6 = 544
you pressed the KM button you should notice that while at 65MPH everyone is flying around you on the highway because you're only going 65KPH = 40MPH
it's a simple mistake don't feel bad!
Old May 14, 2005 | 02:14 PM
Cristiano's Avatar
xviper, CrazyPhuD,
Thanks guys! I thought it was electronic brain failure, as I had a 1988 Accord that had all electrical fail except the spark plugs. Turns out it was brain failure after all; only, it was organic brain (mine) failure in the case of my S2.2K.
BTW S2K 9000rpm & CrazyPhuD, nice cars!!!
ric
Luke 12: 48
Old May 14, 2005 | 02:20 PM
Wisconsin S2k's Avatar
that's EXACTLY what i was thinking. I'm willing to bet xviper's car that's what you did.
Old May 14, 2005 | 02:57 PM
xviper's Avatar
You're pretty liberal with MY car, pal!
Old May 14, 2005 | 03:07 PM
hey, what? you think I'm gonna be liberal with my own?
mikey k
Jul 13, 2007 12:06 AM
rahula
Nov 21, 2005 02:30 PM
energetic
May 16, 2005 04:47 AM
doubleA
Aug 8, 2004 01:43 PM
KJ-Spa02
Sep 4, 2002 05:09 AM
