Billman TCT
Hi all,
I have a Billman TCT and I have noticed that when I start the engine from cold the oil pressure light goes out within the normal amount of time but then after approx 2 secs the light flicks on again for approx 0.5 secs.
Now I imagine this is something to do with the uprated parts that are used in the TCT and it is completely normal, but I just want to make sure it's all right that the light flicks on and off after start up?
I have complete faith in Billman and his products but I just wanted to check it is normal and there's nothing to worry about.
Thanks in advance
Thanks in advance
Originally Posted by apme123' timestamp='1353353683' post='22160259
I dont think the tct is the problem, could be oil filter related or the cam wheel bolt
Originally Posted by Owen_1987' timestamp='1353355129' post='22160321
[quote name='apme123' timestamp='1353353683' post='22160259']
[/quote]
Yep its OEM and it's deffinately the correct part number
You should never see the oil light after the car starts.
My TCT runs higher pressure that OEM, so I assure you that is not the problem.
Did you possibly snag the wire while chaning the TCT? It's right there next to it.
I did unplug the sensor so maybe I have got the contacts dirty and have an intermittent connection problem? Also the temp has recently plummitted in the UK so I don't know if that will be contributing to the problem.
Do you have any other ideas of what it could be?
