Billman’s P1457 DIY
Old 08-16-2012, 02:10 AM
  #41
TurbanRacer's Avatar
I'm PISSED.. As driving to work my CEL lite up.. Here at work and I have two codes.. P1457 and P1457 PD.. What gives!!
igneous (05-10-2020)
Old 08-16-2012, 07:55 AM
  #42
MR.T's Avatar
Start at page one of this thread. The fix/diagnostics bill recommends is the proper procedure for this repair.
Old 08-16-2012, 08:57 AM
  #43
SgtB's Avatar
Easiest way to check would be to monitor fuel pressure and remove the gas cap. That would reveal a vacuum lock.
Old 08-16-2012, 10:32 AM
  #44
MR.T's Avatar
Yeah I'm trying to get the adapter to test at the pulsation damper, per helms. Requires a special tool.
Old 10-19-2012, 03:36 AM
  #45
hatchhero's Avatar
thxs bill, this fixed my cel sry so late LOL
Old 10-19-2012, 05:07 AM
  #46
4forall's Avatar
If either or both of those valves are bad does it do any harm?
Is there any negative effect to running with this code on?
Old 10-19-2012, 07:02 AM
  #47
Billman250's Avatar
Received 1,253 Likes on 763 Posts
Yes, any other code that needs to set you will never know. Plus you are pissing away fuel (in vapor form)
I highly recommend fixing it.
Old 10-19-2012, 07:35 AM
  #48
henrryxd's Avatar
you say its easy monitor the fuel pressure from removing the gas cap? how do i check ? how do i confirm the issue neither being the gas cap or valve set.
Old 10-19-2012, 07:55 AM
  #49
SgtB's Avatar
Mr. T is having a strange problem. A fuel gauge a the pulsation damper is the method.
For the problem Billman is addressing, follow his steps if you're getting a CEL.
Old 10-19-2012, 08:02 AM
  #50
henrryxd's Avatar
haha i thought page 2 was page 1.. ok so its not the gas cap. lols
Quick Reply: Billman’s P1457 DIY
