Billman's TCT
Old Apr 18, 2018 | 12:38 PM
  #91
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Was the TCT a new OEM pinned unit?
Old Apr 18, 2018 | 12:42 PM
  #92
rrurak's Avatar
It was OEM, bought new by myself from Honda, but I have had this one in and out of the car once already, so no pinned when he had it.
Old Apr 18, 2018 | 12:45 PM
  #93
Billman250's Avatar
Top Answer: 1
A TCT cannot be installed without pinning, or bolt retraction, period.
If the tensioner was drawn in ANY amount with the bolts, then it is an install error and will overtighten the chain.
Ask him to briefly explain how it was installed.
Old Apr 18, 2018 | 01:09 PM
  #94
rrurak's Avatar
Yea, I had left the bolt that I used to retract the cylinder prior to install next to the unit in my car. Aside from asking him how he did it, is there any other way you can think of proving the failure was install? Or proving the TCT was, and is still functioning properly, perhaps outside of the vehicle.
Is there technically any other way (besides a worn-out worm gear) for a TCT to fail than this incorrect tension on install? Like I said, I have two TCT's: does demonstrating that both of them function perfectly in hand in a comparison mean anything?
Old Apr 18, 2018 | 04:33 PM
  #95
jivenene's Avatar
Originally Posted by Jah2000
I've been using Billman's TCT for about a week now. Engine noticeably runs healthier, stronger, smoother cruising and also throughout the rev range (accel and decel), much more consistent/even combustions, solid and quiet idle. I notice it most during freeway cruising (super smooth, purrs nicely and pulls stronger) and also during downshifts, decel and engine braking. Blips/heel-toe seems quicker as well (engine noticeably feels more responsive). All around, engine just sounds and feels a lot better throughout the entire rev-range and in all situations (hold steady cruise, response, accel, decel engine braking, etc., etc.). Purrs like a new engine. This is perhaps the #1/Best engine mod/fix you could get and I should have got it a lot sooner when I first got the car. A+++++
Not doubting anything you are saying, have heard this from others here as well, but what is the mechanical explanation for the smoother, stronger engine performance? How can timing chain tension effect engine characteristics so drastically, and how did Honda get it sooooo wrong? And why was this not a factory recall?
Thanks.
Old Apr 19, 2018 | 06:49 AM
  #96
cosmomiller's Avatar
Top Answer: 1
Thanks.
He would have experienced the same engine performance if he had a properly installed brand new OEM TCT too. The problem with OEM is, over time, it does not work as well as when new. Billman's TCT (latest version I believe is X) is a fresh look at how the TCT operates. He built a better one and one that lasts. With the quantity of parts in a typical car, it is not unheard of for some part to not work as well as it could. Hell, parts on spacecraft fail too.
Often times someone in the field has a better view of what works than engineers do in the office. Billman is one of those. His experience and desire to help out fellow S2000 enthusiasts has produced, in this case, a superior TCT. I put one in proactively before symptoms appeared.
Old Apr 19, 2018 | 08:06 AM
  #97
Billman250's Avatar
Top Answer: 1
OEM worm gears do not wear out. That is a misconception people have made, based on the original sandblasting concept. The only way to destroy an OEM worm gear is to take a dremel or sandpaper to it.
The only way your chain can be over tightened with an OEM TCT is if it is installed improperly (not retracted first).
Their install explanation should include how the unit was retracted. If it doesn’t, then it is likely wasn’t retracted.
Old Apr 20, 2018 | 03:13 PM
  #98
jivenene's Avatar
Yeah i read about the worm gear sandblasting, seemed like a weird fix to me. So what is it that wears out in the TCT to cause it to malfunction then? If it works well when new but ceases to work properly later, something went out of spec. I've seen them disassembled before, but there are no rubber bits that could fail. I think just the spring and the metal plunger.
Old Jun 8, 2018 | 12:04 AM
  #99
jivenene's Avatar
Just installed my Billman250 Gen X TCT, man what a difference in engine sound! It doesn't sound like a diesel anymore when I come home from a drive and shut her down. Great piece of mind to know that the proper cam chain tension is being applied now and it is not too tight or too loose at all rpms... Well worth the dollars!
Jive
Old Jun 8, 2018 | 06:06 PM
  #100
JDMchucko's Avatar
Big Thanks to Billman for offering this service for the community. Quick Question, how would you compare your TCT to say a Ballade brand? Does your perform better? cost effectiveness? overall design? Curious to know as a OCD buyer who's looking to replace his TCT.
