Billman's TCT
Old Feb 20, 2016 | 08:31 PM
  #41
Gernby's Avatar
Former Sponsor
After looking at my earlier pics, I see the "illusion" of the other diameter change, but is just an oil ring:
Old Apr 19, 2016 | 09:44 AM
  #42
funat9000rpm's Avatar
Can't wait to get my TCT installed at the Dragon this weekend. My third S2000 and third Billman TCT
Old Apr 20, 2016 | 11:51 AM
  #43
Chitoki's Avatar
Stock bolts bottom out and damage the head? Is that on all OEM tensioners or just yours?
Old Apr 20, 2016 | 11:56 AM
  #44
Slowcrash_101's Avatar
His, if you look close you'll see why.
Old Apr 22, 2016 | 09:07 AM
  #45
TofuProductions's Avatar
Originally Posted by Trustd_1
Originally Posted by Memo6453' timestamp='1455727671' post='23883094
I know TCT can go bad as early as 20k miles, but is everyone just replacing them as a proactive change out or are you all waiting for the slightest ticking and then changing?
my OEM was still functioning properly, but i swapped it for Billman's GenX as preventative maintenance.
This, so far no complaints.
I'm a fiend for preventative maintenance.
Old Aug 2, 2016 | 06:56 PM
  #46
DDmyS2K's Avatar
Originally Posted by Billman250
If you still have it, can you give it a wipe off? If not I will check it when it comes back.
Hey Billman250 I'd like to know more about pricing on your TCT, I have a 02 with 57k miles. I hear a slight rattle and would like to see if replacing my OEM tct will fix the problem. If you see this please contact me ASAP
Old Aug 3, 2016 | 09:30 AM
  #47
Memo6453's Avatar
+1 for Billmans TCT. Had my OEM TCT start to chatter at only 25k miles. Swapped em out and so far so good. Easy install and quality looks great.
Old Sep 26, 2016 | 10:40 AM
  #48
CrashBravo's Avatar
I just replaced my stock TCT with Billman's Product. Very clean piece of equipment. Straightforward install (though I did end up pulling my airbox off). Prompt core refund from him.
Would recommend.
Old Sep 26, 2016 | 11:04 AM
  #49
Chuck S's Avatar
15 minute swap with close to half that time finding my 10mm ratchet spanner -- darn little room there. Allen wrench, needle nose pliers (toothed will give a better grip on the clip-pin). And a paper towel. Out. In, pull the pin. Done. Pack up the old unit and mail back.
I swapped mine in dress slacks and a starched button shirt just after work. I did remove my tie.
Only warning is the removed TCT is the second slipperiest thing known to man and it wants to get away from you.
Preventive maintenance on my part at 40,000 miles.
Fears/complaints about the core charge are specious. The deposit hit my paypal account the day the old TCT arrived in Long Island.
-- Chuck
Old Apr 25, 2017 | 01:28 PM
  #50
LarryFR01's Avatar
How did you order/purchase the TCT?
