Blackstone Labs Summary Analysis: Mobil 1
This was posted at BITOG, and is a valuable service to us all.
https://cimg5.ibsrv.net/gimg/www.s2k...80ee48eca4.jpg |
[QUOTE]Originally posted by Road Rage
This was posted at BITOG, and is a valuable service to us all. And it would be a valuable service to those of us who don't have a clue what all that means if you would be so kind as to provide an explanation. :confused: Thanks |
Moly is a friction reducer and anti-wear additive
Boron can be used in various ways, generally also as a FR and AW -This is based on the intricate crystal lattice structure of hydrated boron molecules. It's lattice structure allows the layers of hydrated boron particles to slide virtually friction-free over each other. Silicon is actually silicone which is an anti-foam additive Calcium is a buffer used to offsent acidity, and as a friction modifier Phosphorous and zinc are your primary anti-wear additives. Phosphorous is usually added at about 80% of the level of zinc. Note that these are levels for SL-rated oils, and are much lower than previous SH levels (for the benefit of the mfr). There have been sulfonates added to bolster the tradition Zinc/Phos mix, but some oil compoanies (like Red Line and Lubrication Engineers) have not rushed in to the SL-game. SUS stands for Sayboldt Universal Seconds, a measure of viscosity - note that there are target vis levels set by the API, within a range for each weight (20,30,40,50) Mobil tends to formulate at the low end of the range. Flash point is the temperature that will light off an oil vapor - generally the higher the better, as it is a good indicator of the oil's ability to resist vaporization when it hits the hottest areas of the engine, such as upper rings and cylinder walls. |
RR,
My interpretation of other postings you have made is that Mobil 1 was a, for lack of a better word, decent choice. Is there anything you see in this new data that would lead you to change your opinion? My humble apologies if I am lacking in interpretive skills. https://www.s2ki.com/forums/index.ph...age&img=151753 |
these numbers must be really reliable?:confused:
Here's my last report from Blackstone for comparison (fuel dilution likely due to cold starts in winter to move car without warming up):
https://cimg2.ibsrv.net/gimg/www.s2k...7b61e62d85.jpg |
Subscribing!
As a user of M1, I'm curious as to the opinions after analysis. |
I have checked my oil many times and i use mobil one.....always comes back perfect. Fuel dilution is normal for a gas engine.
I am confused about the SUS Viscosity at 210 deg. The virgin oil analysis for 10/30 oil posted by BITOG - analysis was done by Blackstone showed as 58.3. Jguerdat's oil was very close to this after 8K miles.
But jguerdat's chart says that the viscosity for his oil should be between 59 and 68. Is 59-68 the normal range for 10/30 oil and Mobile 1's viscosity runs lower than the normal. Seems like RoadRage has mentioned that Mobile 1's viscosities run on the low side. |
It is likely the result of a variance in the tecnician doing the test, or how long the sample oil flow was running before it was taken. Mobil1 is usually rather low on the SUS scale, but nitpicking about a few points is meaningless when one accounts for the variables of sampling and analysis.
I am impressed by the 0w40 - esp the very high flash point. That could be a great all-season oil for people in cold and hot climates. Delvac1 5w40 still gets the nod for longevity and POM for longer OCI's. |
