Body roll...eliminating/reducing
Old Nov 20, 2003 | 12:17 PM
  #31
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by munckee
I've been toying with the idea of swaybars as well.
Old Nov 20, 2003 | 01:04 PM
  #32
drewchie's Avatar
Go with the Saner! I think there's a group buy on them now from the Go Fast Lab (Check with Rylan)
The Saner is adjustable and can be altered to fit the type of driving you plan to do. It will not only reduce oversteer, but also allow you to run 225 tires on the front instead of the 205s. The Muz isn't adjustable, and it only provides a slight advantage over stock, so I wouldn't bother. The Saner is more expensive, but well worth the dif.
The stock rear bar is adequete for most applications and probably doesn't need to be replaced. If you wanted to, Saner makes an excellent rear bar too.
IMHO
Old Nov 20, 2003 | 01:09 PM
  #33
Gernby's Avatar
Former Sponsor
Is the REAR Saner bar adjustable?
Old Nov 20, 2003 | 02:14 PM
  #34
amongmany's Avatar
Thanks guys! So you're running 225's up front on stock wheels? Do you keep the rear the same size (I'm assuming this is 245 since you're clearly not using OEM front tires).
Old Nov 20, 2003 | 02:22 PM
  #35
Gernby's Avatar
Former Sponsor
I just switched from 205/55-16 up front to 225/50-16s, and I hate them. I have always liked 225/50-16 Kumho Victoracers up front, but they have very stiff side walls. The street tires that I have now (Yoko AVS-I) have such soft side walls that the wider tires roll over way too much. I actually have LESS traction up front with the wider tires.
Old Nov 20, 2003 | 04:00 PM
  #36
cdelena's Avatar
[QUOTE]Originally posted by gernby
Old Nov 20, 2003 | 04:09 PM
  #37
Gernby's Avatar
Former Sponsor
Maybe you could go with 225/50's all the way around, and it would even out.
BTW, I didn't actually PAY for these (used) AVS-I's.
Old Nov 20, 2003 | 04:57 PM
  #38
drewchie's Avatar
Putting the same size all around would be a mistake. That's not how our car was designed. Going with 225s without upgrading the sway bar is another mistake.
As for 245s in back, the stock S02 although it says 225 is actually closer to a 245. 245 is the correct replacement size if you're not going with the OEM S02.
As for tires, the shaved RA1s rock for us out in dry California. They stick like glue and wear like iron.
Old Nov 20, 2003 | 05:47 PM
  #39
Gernby's Avatar
Former Sponsor
My point was the 225/50's in the front REDUCE grip due to rollover (for street tires), and 225/50's in the rear REDUCE grip due to reduced width. The two combined might cancel each other out, and have a stock balance on OEM wheels.
Old Nov 20, 2003 | 07:15 PM
  #40
Kekoa's Avatar
