Brake Grease...
Old Jan 11, 2010 | 08:36 AM
gtg749m's Avatar
Default Brake Grease...
Does it matter what kind you get or are they pretty much all the same?
Thanks!
Old Jan 11, 2010 | 08:51 AM
aresk3b's Avatar
I don't know exactly what are u talking about.
But I guess you are mean the antisqueal grease/paste.
Generally I use permatex or the one supplied with brake pads. Applied on my index finger and then applied evenly (not excessive) on the pad back.
Also I clean with brake cleaner the channel where the pads 'ears' run. For stubborn dirt I use a robust brush or and old toothbrush. The I apply a really small amout of High Temperature Grease. I use Saratoga (italian product) High temp grease
Old Jan 11, 2010 | 08:54 AM
CKit's Avatar
Doesn't matter as long as it's high temp. I get the little NAPA packets for a buck.
I think I have a tube of grease somewhere, but I can't find it. So I keep getting those little packets.
Old Jan 11, 2010 | 10:48 AM
zeroptzero's Avatar
I use any form of silicon grease on the brake slider pins, as they have to be compatible with rubber boot/seals. It is commonly referred to as brake grease.
On the pads and caliper contact surfaces, a good quality high temp grease is good.
Old Jan 11, 2010 | 01:06 PM
aresk3b's Avatar
Oh I see what maybe he intended for brake grease.
I use the same grease I discribed above on the brake sliders and boots
Opie Oils
UK & Ireland Traders Forum
Feb 17, 2012 12:35 AM
crockey
Jun 1, 2007 08:11 AM
MitsukillinS2K
Apr 17, 2006 11:46 PM
heath389
Sep 28, 2004 05:46 AM
