Broken Lug nuts/studs! Close encounter
Alright, I have yet to introduce myself to the forum so here it goes.
"Hi my name is Jordan, I recently bought a 2000 Honda s2000 silverstone metallic w/ red interior."
Now that that's out of the way, I ran into an easy fix but big issue the other day. I bought the car about a month ago and noticed it had a snapped lug nut on the front wheel. I was planning on fixing it soon but the other day I was late to school. This inspired me to drive like Emerson Fittipaldi because I had a paper due. I take a turn a little too hard and I immediately knew something was wrong with one of my wheels. So I pulled over as soon as I knew something was up, got out of the car and noticed the wheel was now only being held by a single lug nut. 20 more feet and it would've came off, no doubt (We had to keep pushing the wheel in just to get it on the tow truck) I got it towed back to my house and now it's on jack stands. It could've been a lot worse but it's also something that could've been completely avoided...
I've searched the topic and didn't see anything quite as gruesome as my case. So my question is; since it was violently torn off, is it necessary to buy a new hub or should I just stick replacing the lug studs?
Everything is factory. I'm thinking that the last lug stud that was standing must have had a ton of stress on it, judging by how hard it was to roll it on the tow truck. I will most likely go and buy 5 new nuts and 5 new lug studs to be on the safe side, but I don't know where I should get them from.
I've been working on it and got it down to the hub. I started to start knocking out the studs and I noticed that they are too long to fit out the back. Obviously, I have to get the hub out, which means new wheel bearing. But here is another question if anyone knows it.
Is it really necessary to remove the knuckle and everything too? I would like to stay away from buying that notoriously expensive "ball-joint remover" tool.
I would just like to get the hub out and, if anything, take it to get it pressed.
