Broken Lug Stud
I noticed some strange sounds and a wheel balance vibration on the front left wheel and discovered 2/5 lug studs had broken. Is it necassary to remove the hub to replace lug studs, or can I do it with the hub on the car?
Ok. I wanted to try and do it myself, but after looking into it I decided it looked like more trouble than I wanted to deal with. I just drop it off at the local shop I use. I'm guessing $300 - $400 to have the hub pulled and the lug studs & bearing replaced. Does that sound about right?
