burning too much engine oil
Old Feb 20, 2012 | 02:10 PM
Princeneo's Avatar
Default burning too much engine oil
Im using penzzoil ultra syntetic 10w30 and my car is burning too much oil, i heard castrol 10w30 is better?
Old Feb 20, 2012 | 04:46 PM
eremoy's Avatar
How much is it burning? How hard are you driving it? I'm using pennzoil platinum in my02 and it's not bad at all if i'm nice to it.
Old Feb 20, 2012 | 06:33 PM
Princeneo's Avatar
i just use the car for work every day probably 10 miles a day, i just changed my oil a month ago and when i checked my oil level today it was low already, i had to refill it with 1 and 1/2 qts
Old Feb 20, 2012 | 07:41 PM
Back S2k's Avatar
i switched to castrol from mobil1 and i am burning significantly less. u should however check ur oil level more frequently than once a month.
Old Feb 20, 2012 | 08:18 PM
oyitzpreston's Avatar
Yeah i did the switch from mobil to castrol as well did help quite a bit but still burns some. Get into the habit of checking everytime you fuel up.
Old Feb 21, 2012 | 02:11 AM
nartnailuj's Avatar
Regular Castro or synthetic
Old Feb 21, 2012 | 03:34 AM
Jdrum1's Avatar
Not sure what was in mine when I got it (6 or so weeks ago), but I swithched to Castrol Edge (formerly "Syntec") and things are much better.
Old Feb 21, 2012 | 06:02 AM
Princeneo's Avatar
im switching castrol 10w 30 next oil change but which do you prefer syntetic or not?
Old Feb 21, 2012 | 07:08 AM
golfman's Avatar
try changing/checking PCV. I did that and mine drank a lot less oil right away.
Old Feb 21, 2012 | 07:42 AM
rob-2's Avatar
1qt per 1000 miles is normal. Unless you have an exact miles to quart consumption this is all silliness.
