A/C Problems
Old Jun 6, 2010 | 05:19 AM
jaundice's Avatar
Default A/C Problems
Ok, wierd things going on with A/C. I did a motor swap and relocated the A/C lines. I used a vacuum pump and pulled a vacuum on the system before re-charging it. I used the PAG oil like I was supposed to. Charged to 60 on the gauge. It blows cold.
Now, in the AM when about 80 out, A/C compressor and fan will not come on, and no cold air. In the afternoon, when 95 degrees out, A/C compressor comes on and blows cold air. Whats the deal? I rechecked system pressure last night and it is still 60 psi with compressor running and blowing cold air. It was 98 degrees out when I did this. Then this AM, same thing. 75 degrees, humid and no cold air and no compressor. When I left work and 95 degrees out, AC comes right on and blows cold all the way home.
Help, I'm hot...
Old Jun 6, 2010 | 01:06 PM
Slows2k's Avatar
I removed the Duplicate thread in the FI forum.
You need to take it to someone that has a AC recovery station that can measure both high and low side pressures and evacuate any moisture from the system as well as charging by weight, not pressure.
DFWs2k
May 23, 2010 07:21 PM
REVHIR
Jul 1, 2009 02:09 AM
Pointblank
Feb 2, 2009 04:05 PM
Jsmakr
Jul 16, 2008 09:24 AM
02s2k01s4
Nov 2, 2007 10:31 AM
