A/C Replacement
Old Dec 27, 2020 | 01:25 PM
  #31
trpltongue's Avatar
So...looks like everything is working.
I had a shop evacuate the system, then I replaced the compressor and drier. Shop said they took out a little under a lb of refrigerant. The A/C hadn’t been run in a while, so there wasn’t much oil in the drier or compressor when I removed them. I measured out less than 1.5oz. So I added back in 2 oz of oil. I pulled a vacuum for 2 hrs and it held for an hour. Then I added in ~22oz of r-134a.
seems to be blowing nice and cold, though it is mid 50’s here so I can’t really tell lol.
is there any guidance on low and high side pressure? Good news is the crazy intermittent whining noise from the expansion valve is gone now
Old Dec 27, 2020 | 01:35 PM
  #32
cosmomiller's Avatar
Top Answer: 1
Moving forward, make sure you "exercise" the system to keep everything lubricated and contacts working. I do that on all my cars every now and then irregardless of the weather.
Old Dec 27, 2020 | 01:36 PM
  #33
trpltongue's Avatar
That definitely won’t be a problem in Houston lol!
Old Dec 27, 2020 | 04:13 PM
  #34
fernando.'s Avatar
Glad to know it worked out.
Honda A/C compressors will not engage below a certain temperature so the system doesn't over pressurize. Typically anything below -5c/20f the A/C clutch will not kick on, even if you press the A/C button on the dash.
2K2S2KAP1
Tampa
Jun 30, 2016 04:23 AM
S2KRAYZE
Southern Ontario For Sale
Nov 4, 2015 05:06 PM
Daddy_Danglez
Nov 2, 2015 08:32 PM
Chance S2K
Oct 6, 2015 09:15 AM
