Cabin Filter Replacement
i didnt check the manuel, ya i removed the clips but that plastic peice was still on there pretty good i didnt want to brake anything, also on the ap1 it seems that whole entire thing is all attached under the windsheild that you have to remove :/
Right. And be careful on reinstall that back of white plastic surround is secured. If you can lift back of filter, its not in right.
Be careful not to break the little clips that hold the rubber trim down (which also holds down the cowl cover). Someone figured out a 5mm socket is perfect size to push them up from the bottom without breaking them.
