Cam belt/Timing chain?
Old Oct 28, 2005 | 01:09 AM
Bandit_287's Avatar
Default Cam belt/Timing chain?
Hi All,
My UK S2000 has now covered 53 thousand miles and I just emailed Honda to ask how much a cambelt replacement is and they told me that the S has a timing chain that doesnt need to be replaced.Is this correct ?as i looked in the service manual and it says that the CAMBELT should be replaced at 60,000..I dont want to argue with Honda as im sure they are correct just hope they are as it'll save the expense of changing it.
So cambelt or timing chain?
Many thanks,
Paul.
Old Oct 28, 2005 | 02:04 AM
atomic's Avatar
Yes the F20C does indeed use a chain. Timing chains should be changed a 120,000miles.
Old Oct 28, 2005 | 02:06 AM
Bandit_287's Avatar
Lovely.I'll spend the money on beer instead...
Thanks for your help..
Old Oct 28, 2005 | 04:25 AM
Slows2k's Avatar
The Service manual doesn't list a milage interval to change the chain.
Old Oct 28, 2005 | 06:36 AM
Squeezer's Avatar
wrong. while using a timing chain, there is no service interval. you'd only replace it if the links in the chain stretch or if you are rebuilding the engine.
Old Oct 28, 2005 | 07:06 AM
xviper's Avatar
Maybe in the UK, their timing chains are made with rubber links?
InVTEC
Jul 10, 2011 05:27 AM
faisal668
Sep 13, 2009 06:06 AM
Do$tylz
May 4, 2006 04:10 PM
FULLTHROTTLE
Apr 29, 2005 09:52 PM
tim62
Aug 24, 2004 12:02 PM
