Cam lobe wear mark
Old Apr 16, 2012 | 02:10 PM
hrpfg2's Avatar
Default Cam lobe wear mark
So yesterday I took the valve cover to do a valve adjustment and discovered wear marks on cam lobe.
are wears like that normal?
below is a picture I took.
Old Apr 16, 2012 | 03:12 PM
zeroptzero's Avatar
some discoloration might be normal, but I am pretty sure I see at least one circular scuff mark on one of the low lift cam lobes that is typical of a broken retainer, you may have others but it is hard to tell from the picture.
Old Apr 16, 2012 | 03:20 PM
starchland's Avatar
hard to see from the pic, is the middle of the lobe wearing while you still see the machining marks on the outsides?
Old Apr 16, 2012 | 03:35 PM
hrpfg2's Avatar
by circular scuff mark, do you mean the wear mark goes around the whole lobe? and which one lobe are you referring to?
well, all the wear mark/discolor are all towards the center of lobe.
Old Apr 16, 2012 | 03:47 PM
zeroptzero's Avatar
yes, to me it looks like you are getting metal to metal wear on the low lift lobe in what appears to be the exhaust side of cylinder two (if I'm seeing the picture correctly). Take that with a grain of salt though because the picture can be deceiving and most cracked retainers are on the intake side from what I've heard.
Try to take some more close up shots of the lobes if you can. Have you checked the valve clearances yet, were any of them overly tight ?.
Old Apr 16, 2012 | 04:20 PM
hrpfg2's Avatar
I actually didn't do the valve adjustment nor check for valve clearance after all, I was very bummed out after discovering these marks.
here are a couple other pictures I took.
cylinder 4 Intake side.
cylinder 2 Intake side
Old Apr 16, 2012 | 04:29 PM
zeroptzero's Avatar
the low lift cam lobe on cylinder 4 definitely looks like a broken retainer causing metal to metal wear. The pic of cylinder 2 looks somewhat normal but still hard to tell from the pic, the low lift cam lobe could be just starting to get wear on it, but not nearly as bad as cylinder 4. I think you need to focus on inspecting the retainers for cracking, someone like Billman250 should have a better trained eye for the wear marks, it would be good to get his opinion, take some more pics of each cylinder up close when you have time.
Old Apr 16, 2012 | 04:42 PM
hrpfg2's Avatar
I won't be able to do anything right now as I am away from home and wont return for 3 weeks.
Thank you for your help, I really appreciate it.
and hopefully Billman250 will see this thread and chime in.
Thanks again!
Old Apr 16, 2012 | 05:50 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
wow.
Seems you have a serverly broken retainer on cylinder 4 AND 2.
The retainer is rubbing on the roller rocker, and the hardened metal powder is etching the camshaft.
Old Apr 16, 2012 | 06:57 PM
hrpfg2's Avatar
First, I want to thank you for chiming in!
My ultimate goal was to do a valve adjustment because the car was misfiring in every cylinder but then all this be came visible.
What would you suggest I do next?
and also, I am getting low compression numbers all across.
Can retainers cause low compression?
