Camber and Caster
I went to get an alignment after replacing my control arm and toe arm. But they couldn't get it into spec. The caster on my driver front was about 1.3 degrees off and my passenger rear is about 1 degree off. :/ What would be the cause? Any possible solutions?
has the front ever been in an accident?
very hard to tell, but the front subframe sometimes end up bending on the top side near the motor mounts. you probably won't see any damage from the bottom of the car though.
No no front end damage. But as fas as the rear, I bent the toe arm and lower control arm when I hit a curb. Know how I can straighten out the subframe? Will the caster being off effect anything?
