Camber problem
Old Jun 19, 2009 | 10:57 PM
bigwhite's Avatar
Default Camber problem
the problem started when I sent the car to alignment with a friend.
He came back with the "final value" sheet, and I started to search for problems:
Observation: Straight line driving does not have any problem. when I hit the brake over 60, the car tends to move left, which is obvious
Questions:
If I just simply got SPc camber kit (I am not interested in auto-x, just DD), and adjust front camber, would it be a problem?
Would it be wise to replace rear-right (the defective) ball joint with also SPC (probably I would by one to the left also-to keep symmetry)?
all opinions are wellcome
Old Jun 20, 2009 | 08:48 AM
negcamber's Avatar
Is the car lowered? If so, by how much?
Old Jun 20, 2009 | 10:55 AM
bigwhite's Avatar
yes,it is lowered. Tein s tech, 1inch all around
Old Jun 20, 2009 | 11:50 AM
negcamber's Avatar
Hmmm...1" shouldn't be enough to cause a camber problem. Do you know if the car has been in an accident?
Old Jun 21, 2009 | 07:21 AM
bigwhite's Avatar
No frontal collision, but lots of bumps,holes on the roads, Damaged a rim last year.
Old Jun 21, 2009 | 10:34 AM
negcamber's Avatar
You may need to swap out that left front lower control arm. It just isn't right that you can only get -.2deg camber.
Old Jun 21, 2009 | 10:41 AM
Randizzle88's Avatar
[QUOTE=negcamber,Jun 21 2009, 10:34 AM] You may need to swap out that left front lower control arm.
Old Jun 21, 2009 | 03:31 PM
negcamber's Avatar
At full ride height, I was able to get -2deg front neg camber. At 1" he should be able to get more than -.2deg.
So something must be wrong with the suspension.
Old Jun 21, 2009 | 07:32 PM
Clark's Avatar
Agreed, something on that side is bent.
Old Jun 21, 2009 | 09:19 PM
bigwhite's Avatar
What about braking behavior? would a difference of .3 btw Left and right cause the car to go left, only under braking?
is it common to have brake pressure differences btw L/R in S2k? Shall I check that?
