Camshaft sensor. Limp mode
Hi. I've just changed my engine yesterday and once started back up its in what I assume is limp mode (won't Rev over 3k) it's come back as a camshaft sensor but after swapping them both its still a reoccurring problem. Any ideas im really stuck on it
Check the harness connectors at each sensor. I've been seeing a lot of frayed/damaged ones and even ones where one terminal is partially pulled out of the connector. I'm fairly certain this is your issue if you've already replaced both sensors.
Good luck.
Good luck.
