Can The Headlights Be Adjusted For Height?
Old Jul 12, 2004 | 06:25 AM
solid's Avatar
Default Can The Headlights Be Adjusted For Height?
If so how?
Thanks!!!
Old Jul 12, 2004 | 06:45 AM
Elistan's Avatar
Yes.
Pop the hood and check out the backs of the lights. Somewhere in there is a crown gear looking thing. Use a philips head screwdriver or the like to turn it to change the angle of the light. Sorry, I don't remember which direction is which.
Old Jul 12, 2004 | 11:28 AM
Turtle's Avatar
On an EU market car, the headlights are self levelling. There's an arm to the right rear lower wishbone to a potentiometer, that handles this. Means that to adjust the headlights on an EU car after lowering, you just have to adjust the threaded rod off the wishbone - you don't even need to take the wheel off. Then again, the same EU HID legislation lumbers us with the ugly headlamp washers, so it's not all gravy....
-Brian.
Old Jul 13, 2004 | 11:17 PM
solid's Avatar
Thanx guys.
Mine is an Aussie one so its like the EU one I think coz its got those ugly washers.
Does this mean using the screw dosent work?
Old Jul 14, 2004 | 12:10 AM
Turtle's Avatar
No. It you can still adjust the screw on both sides. But if you've the self levelling, then you can do both sides at once by just adjusting that.
-Brian.
Old Jul 14, 2004 | 06:13 AM
TrueDrezzer's Avatar
My problem is that the left headlight is beaming a bit lower than the right side, after a bumper swap. Is this screw near the coolant reservoir? I've tried sticking all lengths of screwdrivers into the two holes in the fender but haven't come across any crown gears yet.
///Robin
Old Jul 14, 2004 | 06:25 AM
Elistan's Avatar
///Robin
Where are you from? US cars have the left light slightly lower than the right by design - it's so you don't blind traffic in the oncoming lane.
Old Jul 14, 2004 | 12:03 PM
DavidHutchesonJr's Avatar
I agree, my 2003 has the left light a little lower than the right on low-beam. Mine is a US model. I think every US model is a little lower on the driver's side not to blind on-comming traffic. I would say leave it alone. Honda knew what they were doing. Everybody that has an S2K that I have talked to in the US have the same light dispersion pattern. Good question though.
Old Jul 14, 2004 | 12:51 PM
RACER's Avatar
///Robin
There is one for each lamp. I used a socket on mine, although I don't remember what size.
Currahee474
Sep 12, 2020 11:00 AM
Dekan
Nov 3, 2012 08:44 AM
03SBM2000
Sep 28, 2005 09:04 AM
dmcfan
Jan 8, 2005 11:52 AM
