Car died at startup
Old Jan 31, 2007 | 03:13 PM
Turtle636's Avatar
Default Car died at startup
So ever since Ive had my s2000, when I start it up the rpms dip down and they go back up. It dosnt do it that bad but enough to notice it. Well today I started it up and when it dipped down, it went so far down that it died. I went to start it back up and it took a second to turn over but it did start. I still drove it to work, with my eyes on the rpms and I noticed at idle it stays a little under 1k. Was this just a freak thing or is it something I should get checked out?
Old Jan 31, 2007 | 07:08 PM
VashRacing's Avatar
Is it cold where you live? Cause I have mine in storage but when i start it up every week, it will run rough for a little bit then sometimes die. I guess its a fairly common problem, just has to do with the ECU adapting to the cold weather. Its not a big deal, after it stalls and you restart it the car should behave exactly like it should.
Old Jan 31, 2007 | 07:27 PM
Turtle636's Avatar
yea it just started getting pretty cold down here in the maryland region.
Old Jan 31, 2007 | 07:33 PM
toober's Avatar
nothin to worry about it. my car did it when it first started getting cold as well. its just the amps in the battery (not much for the cold starts since ours is so small).
Old Jan 31, 2007 | 08:27 PM
blackout's Avatar
did it to me several times when the cold struck hard. no biggy fires right back up...even when i have clumps of dirt in my exhaust from my land scaping mishap lol
Old Feb 1, 2007 | 12:57 PM
Ishbu's Avatar
its probably your MAP sensor because the SAME EXACT thing happened to me except it was when i stopped at a red light. i took it to honda to get it replaced for free (thanks to extended warranty) and when i got my car back, i noticed that the MAP sensor is zip-tied down.
Old Feb 1, 2007 | 01:31 PM
HARDtoTOP's Avatar
Tell me you didn't accept the car in this condition.
Old Feb 1, 2007 | 02:04 PM
Ishbu's Avatar
i got the car without the MAP being zip-tied down. I heard now from a guy who works at Honda that the new S2000's come with the MAP sensors zip-tied down so that way it doesnt come loose. ever since i got mine zip-tied, ive had no issues
Old Feb 1, 2007 | 02:08 PM
N/Apower's Avatar
If it does it only when cold it very likely is the IAC.
Old Feb 1, 2007 | 03:23 PM
iDomN8U's Avatar
drastic change in temperature will do that... no sweat
