Car dies at idle
Old Feb 9, 2012 | 09:58 AM
learnerspermit's Avatar
Default Car dies at idle
Back story first, I ran AEM ems since 2005 on the car when it had ITB's and then a few years later I removed them off the car and continued to run the EMS. Wit that being said things have been re wired taken off removed put back on etc. The other day I Installed a Mugen ECU. The car starts up and drives great idles but it seems to run a bit rich judging by how much fuel I used on a short drive. I still have not put and OEM fuel pump on it it has a 255lph. Could this by the cause of the large amount of fuel used since the ecu is tuned off a stock out put and the I guess the AEM was tuned accordingly to the fuel flow? Or does the stock regulator regulate it regardless of the flow from the tank? You start the car and and it seems to start fine and idle fine then when you drive the car and come to a stop the car will idle and then hiccup and stall out. Could the engine be loaded up on fuel to cause this? Or should I look elsewhere TPS MAP O2.... Thanks for some input
Old Feb 9, 2012 | 10:23 AM
DFWs2k's Avatar
Bigger fuel pump and everything else stock won't change anything. Your problem lies somewhere else.
Sent using free Tapatalk - Android FTW
Old Feb 9, 2012 | 11:01 AM
Thanks thats what i thought but I drove 40 miles and used a quarter of a tank Just an easy thing to rule out any idea what to check next?
Old Feb 9, 2012 | 05:15 PM
SickoS2K's Avatar
any codes? check your tps.
Old Feb 9, 2012 | 05:47 PM
No Codes not sure if the CEL works with a Mugen ECU.... I have had problems with a the TPS in the past maybe this is the culprit?
Old Feb 9, 2012 | 06:28 PM
ahrmike's Avatar
how are you measuring quarter tank? Remember from 1/2 to 1/4 it drops a lot quicker than from full to 3/4..
Old Feb 9, 2012 | 06:38 PM
it was full and a zeroed out the trip after I filled up today drove 40 miles and then it used a 1/4 of the fill up mean while my wifes car has about 90 miles at the same spot on her fuel gauge and averages 120 + at the half tank mark. So I would get about 80 miles at the have tank mark maybe at this rate.
Old Feb 10, 2012 | 08:59 AM
So tps map iacv an fuel pump is my list to change
Old Feb 14, 2012 | 01:23 PM
Anyone?
Old Apr 23, 2012 | 03:19 PM
Slmd2K's Avatar
Ever find your solution? could be a bad alternator or battery?
