Car electric problem?
Old Jan 26, 2013 | 11:02 PM
BBV S2K's Avatar
Default Car electric problem?
long story short...
Car was running perfect... then doesnt wanna turn on... battery dies... got new battery... start up after 2 long cranks... ran good and perfect... parked home... now same thing... but its doing just 1 thing different... when it cranks.. dash lights flickers... car havent EVER done this before...
uploading video now
Old Jan 26, 2013 | 11:24 PM
BBV S2K's Avatar
View My Video
Old Jan 27, 2013 | 05:30 AM
SouthDakotaS2K's Avatar
Voltage is too low. It sounds like it is cranking way too slowly. Charge the battery up and start the car. While it's running check the voltage at the battery. It should be somewhere between 13.5-14.5 with the accessories turned off. If it is less than that you may have a bad connection or a charging system problem. If not you may have something staying on when the car is off. Like a light or something aftermarket wired in staying on (amps and caps are known for this as well). It still could be a problem with the new batt as well. Did it die overnight?
handsumkrn
Jul 12, 2016 11:51 PM
calvinnnnn
Dec 5, 2014 06:14 AM
S2Kevinn
Mar 6, 2012 06:01 PM
kriz2fer
Jan 4, 2012 10:29 PM
s2ke5
May 3, 2007 06:49 PM
