car jerks while braking
Old Mar 24, 2005 | 02:15 PM
vteconly's Avatar
Default car jerks while braking
When i roll slowly to a complete stop with the brakes applied, the car jerks back and forth, what is going on???
Old Mar 24, 2005 | 02:24 PM
YellowS2kPwr's Avatar
Alignment issue?
Old Mar 24, 2005 | 02:43 PM
DiamondDave2005's Avatar
Crappy road surface? I have that happen at lights on some local highways where the big trucks have worn ruts in the pavement.
Dave
Old Mar 24, 2005 | 02:45 PM
xviper's Avatar
Assuming alignment is good and road surface is smooth, warped rotor?
Old Mar 24, 2005 | 03:10 PM
SpeedxRacer's Avatar
Warped rotor is my guess.
Old Mar 24, 2005 | 10:04 PM
Utah S2K's Avatar
Old Mar 25, 2005 | 08:36 AM
slalom44's Avatar
Top Answer: 1
You may want to read this:
http://www.stoptech.com/whitepapers/...otors_myth.htm
I used to get this brake chatter condition with other cars until I better understood the cause. Besides seasoning my brake pads, I now make sure that if I get my rotors hot I don't keep my foot pressed hard on the brake pad allowing this condition to happen.
Old Apr 4, 2005 | 10:57 AM
vteconly's Avatar
do you think extreme braking can warp the rotors???
i was thinking of taking off the rear brake pads and see if the problem still persists. Will the calipers damage the rotors when the pads arent in there???
Old Apr 4, 2005 | 12:04 PM
xviper's Avatar
DON'T DO THIS! You will either push the pistons out of their cylinders or you will be using the piston itself to clamp onto the rotor. Either one will do severe damage. I'm not sure where you got such a nutty idea.
Extreme braking won't generally warp a high performance rotor, however, uneven cooling might. Also, a common way of warping rotors is when a tire shop uses an impact wrench to put on your rims.
Old Apr 4, 2005 | 12:56 PM
Wisconsin S2k's Avatar
You mean it doesn't say that in the manual in the secret compartment?
