Car shake after spark plug replace, normal?
Old Jun 18, 2009 | 12:24 PM
MegaPower's Avatar
Default Car shake after spark plug replace, normal?
So I change my spark plug today by myself following the DIY here
I replace with the NGK xxxxx-11S (the OEM one)
https://www.s2ki.com/forums/index.php?showt...&#entry13340095
After I change it, I started the car.
Car usually idle at 1600rpm and drop to 800rpm for my AP1.
This time it start at 1400rpm, and fall to 1000rpm, 900rpm, and 800rpm, within 5seconds.
And car is shaking too.
So I shot it off before it fall under 750rpm.
Is it normal? or should I let it run for a couple mins?
Old Jun 18, 2009 | 12:29 PM
CKit's Avatar
No. Not normal. Check your handiwork again. You may not have secured all the connections on the coilpack plugs properly.
Old Jun 18, 2009 | 12:36 PM
MegaPower's Avatar
my bad
turn out to be i forgot to connect one of the coilpack.
everything work right now!
thank you
Old Jun 18, 2009 | 12:57 PM
JP Money's Avatar
^Good think you caught it before anything went bad!
s2Sam
Jun 21, 2016 07:53 AM
402s2000
Apr 5, 2014 03:19 PM
Klutch Master
13
Apr 14, 2010 06:27 AM
vtec4life
Jan 1, 2009 02:38 PM
demonderrick
Nov 19, 2004 10:56 PM
