car shakes when i step on the brake
your shit is f*****d son, ill trade you my mustang for it, the rotars are bomb atleast...no but it you probably had the lugnuts to tight on part of the wheel, if you drive on it long enough it will warp your rotars.
My $.02 ....
1) either have your front rotors turned .... or buy new ones if they can't be turned.
2) change your brake fluid (i.e. bleed your brake lines). Sometimes the calibre gets gummed up from dirty brake fluid and causes the side that is gummed up to pull to that side ....
Rotors can be turned for less than $20 each or at some places for free .... a Large can of brake fluid is about $10 .. (Valvoline Synthetic dot 3/4)
