car vibrates after 70mph?
Old Feb 9, 2009 | 08:47 AM
amkaluta's Avatar
Thumbs up car vibrates after 70mph?
i balanced my rear tires and it still vibrates what can it be its driving me crazy?
Old Feb 9, 2009 | 09:36 AM
macr88's Avatar
https://www.s2ki.com/forums/index.php?showt...=0&#entry639770
Hope this helps, I found this by searching vibration in rear. Don't google search that though
Old Feb 9, 2009 | 09:45 AM
Moddiction's Avatar
Former Sponsor
Did you balance the front wheels? is it worse when on the gas or make any difference at all? If so could be your axle boots. uneven tire wear?
Old Feb 9, 2009 | 04:38 PM
negcamber's Avatar
Is it vibrating mainly under acceleration? Or is it smooth until 70mph?
If the latter...are the tires new? Have you recently spun the car?
If it is only vibrating under acceleration, then your inner CV buckets may need to be swapped. Have you recently lowered the car?
Old Feb 9, 2009 | 08:40 PM
amkaluta's Avatar
no it vibrates only after 70mph smooth on accelerating. it feels like its from the rear but i had the rear tires balanced and it still dose it should i do the front to? it feels like it from the rear? or can it be something else beside the tires i know its not my axles i changed them when my car was shaking while accelerating and fixed that problem but when im crusing like 75mph its got a vibratetion to it? any help?
Old Feb 9, 2009 | 08:53 PM
Moddiction's Avatar
Former Sponsor
Do you feel it in the steering wheel at all? I thought it was the rear of my car as well but wound up just being the front wheels needing to be balanced. So above 70 mph even off the gas you have the same vibrations? If thats the case then maybe a bend in a wheel, tire pressure, uneven tire wear or wheels needing to be balanced would be the most likely culprits.
Old Feb 9, 2009 | 09:49 PM
amkaluta's Avatar
no i dont feel it in the steering wheel. but my car is lowered so it dose eat some tires. and yes above 70mph even off the gas it still has that vibration in it its driving me carzy.... so you think it can be my front tires?
Old Feb 9, 2009 | 10:48 PM
sparks411's Avatar
You might have something bent or need to have an alignement done in the front. A lot of times it is something to do with your front tires.
Old Feb 10, 2009 | 06:26 AM
s2kobsession's Avatar
not sure but do you have OEM rims? If you have aftermarket rims and no hubcentric rings you will feel the vibe for sure!
Old Feb 10, 2009 | 08:15 AM
amkaluta's Avatar
NO THEY ARE STOCK WHEELS...
