car wont start...
More info would help! The (ESM) should not prevent the car from starting I don't think but it can make your car run like crap until you solder the connections.
What is it doing or not doing? Is it turning over at all? rough idle? throwing any codes?
Originally Posted by BaCkOfF' date='Feb 21 2005, 01:17 AM
the engine wont start, just cranking as if the battery is dead...the only code was EPS..
Check all your fuses. One may have been blown (maybe the fuel pump one) when the installation was done. Also double check the wiring. Perhaps the wrong wire was cut or spliced into.
Originally Posted by BaCkOfF' date='Feb 21 2005, 10:30 AM
checked evrything..seems alright. took out the esm and put it back to stock..still gives low cranking. i ll try to jump start the car.
yes i could hear it..we even checked to see if theres fuel going into the engine. everything sounds normal when turning on the key..it just wont start thats all. all u can hear is CLICK CLICK. do you think its the battery?
YES. Assuming the only parts of the car you monkey'd with were the bits necessary to install the supercharger.
You can purchase a battery charger for $20-30 dollars. Attach the device and let the battery charge overnight. Report back with your success story.
