CAR WONT START
Old Apr 17, 2009 | 01:18 PM
S2K Sideways's Avatar
Default CAR WONT START
I took the car out of my garage , and it started up no problem ... I then shut it off to give it a wash. Then realized that i should move it more front into the shade...thats when the car wouldnt start... it cranks no problem but wont start ....
-Checked the fuses and everything is ok
-Smell gas when im sitting in the car but no smell from the engine bay
-no leaks underneath the car showing signs of a broken line
What could be causing this?
-I also pulled out all the plugs and they were a bit soaked in fuel- cleaned them and put them back , but nothing still...
HELP please someone
Old Apr 17, 2009 | 01:25 PM
ahrmike's Avatar
Hold the throttle WOT, then crank for a bit- this cuts the fuel so if your car is flooded, it will clear up. If it still doesnt work, idk - You got fuel, so its gotta be a spark problem. (if it started up right before that + its cranking)
Old Apr 17, 2009 | 01:44 PM
i tried WOT and still nothing.. dont get why im smelling fuel though...im losing my mind lol
Old Apr 17, 2009 | 01:45 PM
its crazy how it started right up 2 mins before that though
Old Apr 17, 2009 | 02:02 PM
crazydude's Avatar
i agree...lack of spark might be the problem.
it is odd that it wont catch a bit of ignition at all. Almost sounds like all plugs are not working.
Did you wash your engine bay at all? Do you use a pressure washer???
Old Apr 17, 2009 | 02:49 PM
no i didnt wash the engine... I just checked the spark and its sending a weak spark...seems like only fuel is shooting into the cylinder causing the smell.... thinking it may be a crankshaft/camshaft sensor? or maybe even my motor just gave out somehow : ( ...where do i go from here?
Old Apr 17, 2009 | 03:21 PM
ahrmike's Avatar
I was thinking the same thing crazy, that maybe you got something wet (ECU?) Wait for a day, try cranking it again. If youre getting a weak spark, the sensors should be fine..it wouldnt send a spark at ALL if anything.
When you 'took out all your plugs' did you let the engine air out (let fuel evap)?
Old Apr 17, 2009 | 03:25 PM
i took the plugs out and cleaned them , waited about 10 minutes and cranked the motor without the spark inside to let any extra garbage buildup get out of the cylinders.... should i have let it sit longer?
Old Apr 17, 2009 | 03:26 PM
crazydude's Avatar
Do you have a heated garage? push it in your garage and perhaps let it stay warm for a day and evap off the water.
I am sure someone will post a helpful response...
I hope its not your daily driver
Old Apr 17, 2009 | 03:30 PM
no not my daily , but we just got nice weather here in nyc and this suckss ... should i let it sit with the spark plugs out ? or just let it sit in the garage the way it is?
