CEL 0710
hello so it is a ap2 2006. it had a misfire in cylinder 4 so i checked the sparks and they were due for a change. so i put ngk lasers in all four. i did notice some burn marks on the ignition coil. so i will change the coil to a different cylinder right now to see if i get a misfire in that cylinder.
CEl light is on and the VSA ! light is on and just turned off.. i will drive it for a while and see if it comes back on.
i plugged in the scanner and it gives me the code 0710. what should i do for this??
ill update shortly with more info and pictures of codes.
thanks
also i am using the autel maxiscan 309
and if my memory is correct it was $0710 and 0710pd
and it stated on the screen cylinder 4 misfire
