CEL AEM V2 2004 s2000
Old Jan 16, 2005 | 07:57 PM
ac09lude's Avatar
Default CEL AEM V2 2004 s2000
well i put my AEMV2 on my 2004 i ran all my vacuum line the same as my friends 2003, (he has a PRM intake) and after about a hour of driving the CEL came on what do u guys think it is? please help me i cannot look at that light. i did a search but still confused....
thanks
Old Jan 16, 2005 | 08:04 PM
Fobolous's Avatar
Were those vacuum line secure? Last time I installed AEM CIA I forgot to tighten those loose vacuum line and as I was driving the secondary air sensor grind a bit to the belt and it took a piece off of it which causes CEL to come on.
Old Jan 16, 2005 | 08:06 PM
KAI-MIKAZEE's Avatar
do a good search...
XViper's got a good pictured detail of the install
Old Jan 16, 2005 | 08:14 PM
ac09lude's Avatar
fobolous did you reset the ecu after you fixed the problem or did the light just go off
Old Jan 16, 2005 | 08:16 PM
xviper's Avatar
One or more of the following has happened:
1. You got the lines crossed.
2. You have a loose connections in one or more lines.
3. You put the white one-way check valve on backwards.
4. You damaged one of the lines and it's leaking.
Trace everything as shown in this thread:
https://www.s2ki.com/forums/index.php?showtopic=105368
Once you get it all correct, reset the CEL light like this:
http://forums.s2ki.com/forums/index.php?showtopic=183490
Old Jan 16, 2005 | 08:28 PM
Fobolous's Avatar
I have a scan tool on my laptop.
Old Jan 16, 2005 | 08:30 PM
ac09lude's Avatar
i'm going outside now to check this out - i cannot sleep knowing the S has a problem...
Old Jan 16, 2005 | 08:56 PM
ac09lude's Avatar
well i just went outside and it was the same as the pictures that xviper has posted i took some pictures maybe you guys see something.
Old Jan 16, 2005 | 08:58 PM
ac09lude's Avatar
Old Jan 16, 2005 | 08:59 PM
Fobolous's Avatar
I think the vacuum lines are different in lenght too are they not?
