CEL after car in storage
Old Apr 13, 2008 | 05:54 AM
Kobe's Avatar
Default CEL after car in storage
have not been able to use the car for approx 6 months.. was kept in a decent garage over winter.
tried the car 2 weeks ago to check it was OK ahead of having to drive it, after charging the battery a bit - it started up first time and ran smoothly for 5 minutes - seemed as normal. Didn't drive it.
restarted it yesterday (again a bit of charging on the battery required)..
straight away it didn't sound good with a constant CEL coming up instantly.
the engine was rough and was popping and spluttering coming off the throttle and didn't want to idle properly.. would eventually stall
plenty of wet black gunk coming out of the exhaust.
it seems there are 2 codes on the ECU - which come back after reset,
P0107 0 - 3 --------------- Manifold Absolute Pressure Circuit Low Input
P0108 0 - 3 --------------- Manifold Absolute pressure Circuit High Input
P0335 0 - 4 --------------- Crankshaft Position (CKP) Sensor Circuit Malfunction
P0336 0 - 4 --------------- Crankshaft Position (CKP) Sensor Range/Performance
car is a JDM model year 2001, modifications to the car-
AEM inlet
mugen manifold
mugen exhaust
any thoughts or ideas? appreciate your help.
Old Apr 13, 2008 | 08:38 AM
icemans2k02's Avatar
sounds like maybe a vacuum line. didnt have any rats in there did ya....
Old Apr 13, 2008 | 08:43 AM
R3DS2K's Avatar
you usually get the CKP codes if it needed to be jumped
also cars here in the states that get parked for along time gets rodents under the hood chewing on wires..
Old Apr 13, 2008 | 09:13 AM
Kobe's Avatar
maybe in charging the battery this happened?
do you know the fix for this?..
Old Apr 13, 2008 | 10:10 AM
Bliss@5200's Avatar
could try to reset the ECU... just throwing it out there.
Old Apr 13, 2008 | 11:34 AM
R3DS2K's Avatar
charging wouldnt cause that code.. but its best to disconnect the battery from the car before charging .
should change your oil and just reset the code and see if the codes go away
reason for the CKP code from jumping the battery can be cause due to the abnormal cranking speed before starting
Old Apr 13, 2008 | 11:55 AM
Kobe's Avatar
have taken the battery off and will put it on a slow charge over night
will then go around the wiring of these sensors to see if anything has come loose..
fingers crossed it is something simple as this
Old Apr 13, 2008 | 12:47 PM
i hope for ya man. good luck!
ousi
13
Oct 5, 2011 07:38 AM
jbird0007
Sep 25, 2011 08:23 PM
j8mie
Feb 13, 2008 11:53 PM
vjarnot
Dec 10, 2007 05:34 AM
Luis
Jun 29, 2004 12:48 PM
