CEL after FIPK install
Old Aug 7, 2008 | 05:09 PM
IntenseImports's Avatar
Default CEL after FIPK install
Hey guys installed a K&N intake on my car about a couple of weeks ago, and after 30 miles or so it threw a code. It came up as P0411 Secondary Air Injection incorrect flow. Any clue whats casuing this? Thanks.
Old Aug 7, 2008 | 05:17 PM
Togobox's Avatar
you probably will need an air pump and relay with this code.
Old Aug 7, 2008 | 05:19 PM
Howcome? It was the proper system for the car.
Old Aug 7, 2008 | 05:24 PM
Togobox's Avatar
according to the Code you have and S/B from honda.
Old Aug 7, 2008 | 05:37 PM
s2kBryan916's Avatar
Could be a pump, most likely the check valve.
Check your vacuum lines first before you do anything.
Old Aug 7, 2008 | 06:01 PM
Slows2k's Avatar
You've hosed up the vacuum line routing.
Old Aug 7, 2008 | 06:18 PM
Togobox's Avatar
wait yea you might hooked up the vacuum line to the wrong place like Slows2k said.
Old Aug 7, 2008 | 06:28 PM
HotDamnitsDavid's Avatar
Yep. That's what happened with me and a few others that installed the FIPK.
Old Aug 8, 2008 | 02:50 AM
Olegator's Avatar
yep....there are two small hoses that have atendency to slide off when you are messing with the intake, look for them near the injectors.
Old Aug 9, 2008 | 05:55 AM
midnightmethane's Avatar
same code came up for me about 3 weeks ago...the selonoid that is mounted on the intake arm has 2 little vaccum lines at the bottom of it...check to see if they're still on and also check to make sure they're not crossed...what i did was zip tie em to the nipple...they can slip off...i've had my fipk since about 3 or 4k (currently have 39k)...so there's a good chance that's what it is...and like other members said before...also check the connection at the source (ie: where those little vaccum lines are supposed to be connected on the otehr end).....cleared the code immediately for me...hope this helps
