CEL on because of Gas cap?
It's too bad the fuel cap will cause a P1456, not the P0411.
P0411 is for incorrect flow of the air injection system.
1st thing is to check all the vacuum lines to the control solenoid, and make sure the solenoid and vacuum tank are not damaged.
Originally Posted by Ap2S2000,Mar 12 2010, 11:10 PM
how can i fix this p0411 code? i mean i know what is it now but what should i do now to fix it? and i do have an short ram intake in my car. thanx
once in a while i get CEL but i didnt want to have to pay 80 bucks for a stupid reading. so first thing, i checked the gas cap, and it was loose, so i cliked it 4-5 times, resetted the ecu, and didnt come back for a while.
I check once in a while to see if the cap is tight or not, and before the light comes on, it always seems tight. but when the light comes on the cap is looose. so i assumed its the cap
I don't know about on 05's, but on my 06 the gas cap didn't throw a CEL it threw a warning message on startup which was fixed in a week of driving cycles.
But google works too, I found this in sub 20 seconds. http://www.honda-tech.com/showthread.php?t=2472262
I had the same problem a while back, it was giving me P1456. Now what I do is when i tightening the gas cap I press it against the filler tube kinda hard as I slowly tighten the gas cap, so push on it kinda hard while screwing it on slowly, hope that helps.
Slow, I know you told me the same thing youre telling this guy...but:
I got the p0411 code, but it went away after I tightened the gas cap properly. Been that way for almost a year, and no signs of it coming back. ::knocks on wood::
Turkey tastes good at Thanksgiving too, doesn't mean the 2 DTC's have anything to do with each other.
2 separate emissions control systems. 2 separate monitors that run for each DTC. Tighten the cap all you want. Not going to fix a P0411
