CEL fix?
Old Feb 14, 2009 | 10:06 AM
S2KballinOut's Avatar
Default CEL fix?
so here is my dilemma:
i hae a 2005 AP2. i recently had my new ACT clutch and flywheel installed by a reputable shop in san antonio, TX. it ran fine. the next day i was driving on my way to CA and the maintenance required light came on. i was thinking it was up for tune up and/ or oil change. Then 200 miles later the Check Engine light came on. i have since changed the spark plugs and nothing.
Can anybody help me!!!
Old Feb 14, 2009 | 10:15 AM
Back S2k's Avatar
Why would you change the spark plugs? You need to go to a shop or autozone or anyplace with a scan tool so they can tell you what code or codes you are throwing. Then maybe we can help you. You cant just fix the CEL if you dont know why its on.
What I would do is go back to the shop that did your clutch install and tell them to fix it because it was fine b4 the install.
BTW maintenance required light dosent just turn on it blinks for a while before it starts being on 24/7. Theres a diy on how to turn it off search for it. Maintenance required light is a scam just so you can go to the dealer and they can take your money. Do all your maintenance yourself like a real s2000 owner.
Old Feb 14, 2009 | 01:31 PM
negcamber's Avatar
As Back says...get the code and search on that. If you can't find any threads on the code, then post it up and more than likely someone can help.
Old Feb 14, 2009 | 01:37 PM
Slows2k's Avatar
https://www.s2ki.com/forums/index.php?showtopic=378792
Old Feb 15, 2009 | 10:50 AM
i went to autozone and came to find out that they dont do free code reading anymore because they are not mechanics so they r not allowed but AAMCO does it for free so im gonna go there tomorrow. thanks for the help guys. i will post the code tomorrow.
Old Feb 17, 2009 | 11:19 AM
so it turned out to be the O2 sensor on header. code was P0138 O2 sensor 11 circuit voltage too high. anybody ever get that?
Mr.duc
Jun 5, 2017 06:53 AM
la_fever323
Mar 16, 2014 10:49 AM
Eyal s2k
Jul 24, 2008 09:01 AM
litre-eater
Nov 28, 2007 06:07 PM
Saki GT
Jan 9, 2005 06:34 PM
