cel light every once in a while since intake
Old Mar 6, 2007 | 02:44 PM
s2kspa02's Avatar
Banned
Default cel light every once in a while since intake
i installed a cold air intake and followed the steps from the site and looked over a few peoples pics. I have everything going the right way, but every once in a while the CEL pops on. I use to have a civic and there was a plug you could trip and it would flash the light a few times will the s2k do this if not i guess i need the obd2 reader. car runs the same and it rarly happens. didnt know what the deal was.. happen about 3 wks ago then just happen again to day. any help would be good.
Old Mar 6, 2007 | 03:21 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Terminals 4-9 of the OBDII connector will flash blink codes.
You'll get code 60 if it's the vac lines.
Old Mar 6, 2007 | 03:25 PM
Slows2k's Avatar
Old Mar 6, 2007 | 06:00 PM
gomarlins3's Avatar
Pull the code.
Old Mar 7, 2007 | 03:16 PM
s2kspa02's Avatar
Banned
i need to pull the code yes but with out the obd2 reader there is no way to check it right
Old Mar 7, 2007 | 03:18 PM
Slows2k's Avatar
You can jump 2 pins in the DLC connector or go to autozone and have them pull it for free.
Old Mar 7, 2007 | 03:34 PM
s2kspa02's Avatar
Banned
witch to pins and you mean the 16 pin connector right... loving the hard top i;m searching for one also
Old Mar 7, 2007 | 05:55 PM
Billman250's Avatar
Top Answer: 1
Old Mar 7, 2007 | 06:02 PM
beeenguyen's Avatar
theres a white check valve on one of the vacuum lines, common problem, could maybe have it backwards? that would usualy cause cel lights, after intake installs
Old Mar 7, 2007 | 06:38 PM
Utah S2K's Avatar
Originally Posted by Billman250,Mar 7 2007, 06:55 PM
Billman knows his stuff! If you don't know how to jump the connector to the noted pins then take it to any auto part store, as noted above. They will pull the code for free in hopes of selling their goods!
Utah
Note:
New Intake- Check check valve orientation. OK- Then check hoses. Some kits have 3mm hose which is loose and may leak (i.e. early AEM) on certain cars. If the interconnect hoses just slip right on then take them to the local store and go one size down. There should be a slight resistance. If the hose has taken a set then just cut off a short piece off each end. By the way, if you do replace the hoses, the new hoses come in COOL colors!!!!
