CEL and low gas (no bar/one bar)
Old Mar 31, 2003 | 01:50 PM
rocketman's Avatar
Default CEL and low gas (no bar/one bar)
Anyone ever had their check engine light come on when you've let the fuel level get really low?
symptoms: started car, no bars on fuel guage; when let off gas after starting, idle dipped very low, like it was going to stall. Similar behaviour when driving slowly - when let off gas, idle dips very low then comes back up.
Drove home OK (~20 miles), but check engine light still comes on and the idle dip is still there if I let the car sit for a while, then start it back up.
Is this a real problem that is something else, or just a "hangover" from letting the gas get down to the dregs?
Old Apr 1, 2003 | 02:16 AM
jguerdat's Avatar
Is the gas cap on tight?
Old Apr 1, 2003 | 07:02 AM
rocketman's Avatar
yeah, first thing I did was look in the owners manual to see exactly the light was supposed to mean and saw the stuff about the gas cap. That's why I wondered if it might be somehow related to driving with a very low fuel level.
If this had happened with a fuel level that was not so low, I would just take it in to have it looked at. If it is some temporary condition due to the low fuel level, I don't want to go thru the trouble of taking the car in and having them tell me nothing is wrong.
Old Apr 1, 2003 | 07:16 AM
turbo_pwr's Avatar
Fill her up and reset your ECU. It's actually a common occurrence in other cars I have owned. After driving it around for a few days it goes away. But I just reset the ECU.
Old Apr 1, 2003 | 09:38 AM
rocketman's Avatar
was hoping it would go away without the reset - manual says if the problem has gone away, you need to go three "trips" before the light will go away. Not sure what the definition of a trip is but if that doesn't work, I'll reset ECU. If it doesn't go away at this point, I'll assume something is broke and take it in for service.
ChineseDelivery
Aug 11, 2010 01:47 PM
why_2k
Jul 9, 2010 04:14 PM
yyyiiikes
Apr 17, 2006 12:29 PM
TwistedS2k
Nov 15, 2004 01:54 PM
RCR S2
Nov 25, 2003 09:27 AM
