cel's need some idea's
Old Apr 30, 2009 | 06:36 AM
drhess06259's Avatar
Default cel's need some idea's
so i got my car started after i put a new head on it, and i got codes, p0300, p0301, p0302, p0303, p0304. did a compression, it's not bad, 190-190-182-208. when i first started it the car was running really rich so the plugs are black but they are new denso's(can you clean denso iridums?), also the car has sat for 10 months so the gas could be bad(not sure how to fix that?). The car also idles at 1200 rpm and some times when i come off the throttle it surges a little. any help would be apreciated as i go for tuning sunday... and want it to be perfect. there is also a slight smell from the exhaust, not really sure how to describe it.
Old May 2, 2009 | 07:45 AM
negcamber's Avatar
https://www.s2ki.com/forums/index.php?showt...&#entry15043510
Old May 2, 2009 | 06:46 PM
silvery2ks2k's Avatar
put a bottle of fuel injector cleaner in your tank fixed my misfire in one tank of gas cost about 6 bucks.
Old May 3, 2009 | 06:39 AM
siik_ap2's Avatar
adjust your valves..i see s2000's come in at my dealer all the time with missfire codes..99% of the time its in need of valve adj.
Old May 3, 2009 | 06:51 AM
thanks for the help problem soloved it was the gas, had a little bit bad gas in there. I guess
Old May 3, 2009 | 07:05 AM
Bertin-S2000's Avatar
hello my friend, i was having the same problem and the same CEL's, so i start changing the plugs but nothing change, then i decide to check my fuel tank because there was a slight bad smell from the exhaust, so i take out my fuel pump and look what i found:
https://www.s2ki.com/forums/index.php?showtopic=690831
after cleaning that, putting a new fuel filter, cleaning the fuel injector filters, I put new gas and all CEL's dissapear.
Kidblast
Sep 3, 2016 01:17 PM
lunardeathgod
May 8, 2012 12:13 PM
04White_S2000
Jun 8, 2010 07:41 AM
drhess06259
May 23, 2010 09:25 AM
MB06
Aug 3, 2004 05:04 PM
