ceramic coated mild steel vs stainless steel
I was wondering if anyone could help me understand the benifits of stainless steel verses ceramic coated mild steel as far as headers are concerned?
I will be purchasing one of those DC headers... and have it coated by www.hpcoatings.com. I was wondering if there would be any benifits in getting a SS version of the header vs a cc coated mild steel since I am having it coated anyways.
thanks,
-Shing
thanks,
-Shing
There are two primary benefits to stainless in a header.
First, it doesn't rust. Even coated headers, subjected to enough heating and cooling cycles and weathering can start to develop pinhole rust.
Second stainless conducts heat poorly compared to mild steel. Thus, it tends to keep more heat in the exhaust gas and out of the engine bay. Coating a stainless header should give you better thermal characteristics than a coated mild steel header.
There are other benefits and drawbacks (the thermal coefficient of expansion is different, its more expensive, etc.), but those are the most important IMO.
UL
UL
Stainless steel is about 8.0 g/cc (AISI 303)
Mid-grade mild steel is about 7.85 g/cc (AISI 4000 series)
Steels as a whole vary between 7.75 and 8.25 g/cc. I choose the 2 grades as a representation, someone could spend some more time and find the "perfect" steel.
That's a whopping 1.88% weight difference. Add on the ceramic coating and your weight is a wash.
I personally would go with stainless for the properties that shingles mentioned - resistence to corrosion and thermal properties. Or just use Ti
08s2000CRbackinblack
Oct 15, 2008 12:43 PM
BrandonS
Apr 14, 2003 11:00 AM
