Changed diff fluid
Old Aug 31, 2008 | 01:52 PM
Slick2K's Avatar
Thumbs up Changed diff fluid
My '05 S2000 has 6,800 miles on it. I changed the diff fluid this weekend to Mobile 1 75w90. I only found two tiny shavings on the drain plug magnet and I understand this is completely normal. For some time I have been hearing a whine coming from what I believe is the differential. The whine is only noticeable from 52 - 60 mph in 5th and 6th gear at a constant speed or while slightly accelerating. The whine stops immediately if I let off the accelerator or put it in neutral.
I was really hoping that the whine would go away but to my dismay, it may actually be slightly louder now that I've gone to synthetic gear oil.
Is this normal or should I have my dealer take a look?
Old Aug 31, 2008 | 02:46 PM
INDYMAC's Avatar
I've been noticing quite a bit of gear whine this summer too. Even more so after switching from LE607(dino) to LE1605(semi-synthetic). It's been a hot one here in Texas, so I've been driving with the top up. The road temps are taking the gear oil to higher temps quickly, so it doesn't take long for the whining to start. I think I may try a 85W-140 dino GL5 next summer, if there is such a thing.
Old Aug 31, 2008 | 09:31 PM
dc503's Avatar
My previous 05 and my current 06 both demonstrated a faint whine during the same circumstances described. I briefly used Mobil 1 75w90 previously and I'd venture to say that's when the whine was the loudest and now the quietest after I've made the switch to LE1605 (last 10k miles). I have also experienced a lot quieter operation in all situations, which is not surprising given it's close to the spec'd 90 SAE.
Old Sep 1, 2008 | 09:15 AM
2007 Zx-10's Avatar
Banned
https://www.s2ki.com/forums/index.php?showt...&#entry14052213
I'm running Amsoil 75-90 GL-5 Gear Lube...smooth as silk (for now)
but I also read this
http://www.bobistheoilguy.com/forums/ubbth...&Number=1215282
People are going to say that any 75W90 or 80W90 fluid will do, but it is incorrect info as old straight 90 is new SEA 110. IMHO, this is why so many people have problem nowadays with whining diffs. I had too in subaru after using Redline 75W90.
Old Sep 1, 2008 | 06:35 PM
s2kvince's Avatar
Identical to what I'm experiencing.
https://www.s2ki.com/forums/index.ph...pic=627087&hl=
Looks like it's common. I may swap fluid once I pick up a pump.
Old Sep 1, 2008 | 07:15 PM
9kFever's Avatar
Sure its not the intake howl? That is the exact speeds it does it at.
Old Sep 1, 2008 | 07:54 PM
2007 Zx-10's Avatar
Banned
Factory fill? Mileage?
Old Sep 2, 2008 | 08:42 AM
tan0116's Avatar
If the noise isn't constant with speed I think it's the intake howl you are experiencing. Sounds to me the throttle is causing this sound with <=20% throttle input.
Old Sep 3, 2008 | 03:50 PM
Slick2K's Avatar
I have an apt with my dealer tomorrow and I'll let you guys know what the outcome is. The service manager is going to ride along so hopefully he'll agree that something is wrong.
If it was intake whine, it wouldn't be speed dependant. It would be RPM dependant. Being that it's only audible between 52-60 mph, and the whine is comming from the rear end, I would think it almost has to be a diff issue.
Old Sep 3, 2008 | 04:49 PM
s2k aok's Avatar
good luck with your appointment...
