Changed trans and diff fluids yesterday
Old May 31, 2015 | 02:51 PM
cdubea's Avatar
Default Changed trans and diff fluids yesterday
My 2008 has 16k on her, so I decided it was time to change the tranny and diff fluid.
Both were straightforward, except the fill port on the diff. Don't know how I'm supposed to get a socket with a torque wrench on there, so I used a wrench to loosen and tighten.
The old tranny fluid was clean as the new stuff. The diff fluid was murky and nasty looking. Perhaps I need to change the diff fluid more frequently.
The drain plug in the trans did not have a magnet but the one in the diff did. There was a small amount of fuzz on the plug that I cleaned off.
The difference in shifting is today is amazing though.
I dedicated some small spray bottles from the BORG to use in pumping fluids into the various places. Works great. I've labeled each one so no crossover in the future!
Next weekend is the valve adjustment and then I'm done with spring maintenance!
cheers,
Old Jun 1, 2015 | 03:17 AM
Slowcrash_101's Avatar
Snug it tight, you really can't get a tq wrench in there. You can use a bathroom scale and the length of your wrench. Say it's 1.3' so you divide 33/1.3 = ~25.38 so to get 33ft lbs you need to pull yourself off the scale with the wrench until you weigh ~25lbs less.
Old Jun 1, 2015 | 05:52 AM
redlineracing's Avatar
FWIW...I change the trans & diff fluid in my 03 every 10k.It's probably overkill,but it's cheap & quick.After 102k miles,NO probs.
\rlr
carolina
Old Jun 1, 2015 | 06:16 AM
cosmomiller's Avatar
Top Answer: 1
You can also practice with the setting on another bolt. You will get pretty close to the "feel" of it. Most good mechanics can get pretty close because they have been doing it so much, its second nature to them.
Old Jun 1, 2015 | 11:27 AM
DogBiscuit's Avatar
i call that gud-n-tite torque spec.
mambo
Apr 20, 2014 05:33 AM
s2kbenztech
May 14, 2008 03:35 PM
evolution
Apr 29, 2008 04:56 PM
dmw16
Jan 25, 2007 08:05 AM
SaV
Nov 11, 2001 08:14 PM
