changing out the clutch fluid, help
Old Sep 11, 2003 | 09:39 PM
s2kpdx01's Avatar
Default changing out the clutch fluid, help
I have been noticing kinda of a sticky feeling when I let my clutch out slow or up slow. I am thinking of just flushing the clutch fluid and see if that makes it go away. what do you guys use? OEM fluid? is there any reason to use an aftermarket fluid? Thanks.
Old Sep 11, 2003 | 10:04 PM
xviper's Avatar
The book calls for DOT 3 (or 4) for the clutch. I used DOT 4 Valvoline synthetic at the last flush.
Old Sep 11, 2003 | 10:42 PM
S2KYSK's Avatar
[QUOTE]Originally posted by s2kpdx01
[B]I have been noticing kinda of a sticky feeling when I let my clutch out slow or up slow.
Old Sep 12, 2003 | 04:47 AM
cdelena's Avatar
Changing the fluid is pretty easy to do and sure worth a try. Many of us have found that there was no lubricant used (or at least visible) on the clutch and shaft so the components did not move smoothly and quietly.. but that is harder to deal with.
Old Sep 12, 2003 | 06:13 AM
s2kpdx01's Avatar
[QUOTE]Originally posted by S2KYSK
[B]
I am having same symptoms...
Old Sep 12, 2003 | 06:16 AM
xviper's Avatar
I have a bunch of Super Blue ATE lying around, could I just use that?
As long as it is still sealed and check the specs to ensure it meets DOT requirements.
Old Sep 12, 2003 | 06:21 AM
Gernby's Avatar
Former Sponsor
If it were me, I would look for the longest lasting, least hygroscopic fluid. The temperature demands on the clutch fluid are very small compared to the brakes. There isn't much reason to use an expensive, high performance, short lived fluid.
Old Sep 12, 2003 | 07:39 AM
s2kpdx01's Avatar
[QUOTE]Originally posted by gernby
[B]
Old Sep 12, 2003 | 07:44 AM
xviper's Avatar
[B]
That is a good point.
Old Sep 12, 2003 | 08:02 AM
s2kpdx01's Avatar
[QUOTE]Originally posted by xviper
[B]
It's pretty cheap - about 5 bucks for a 400 ml can and that's all you'll need.
