Check Engine Code
Old May 2, 2005 | 02:27 PM
JimmyB's Avatar
Default Check Engine Code
Can anyone tell me if they have seen a P1457 ODB II code and if so what is it?
Old May 2, 2005 | 03:09 PM
Slows2k's Avatar
It's a Evap system leak on the canister side. Possibly a stuck/bad vent shut valve. I'd reccomend seeing a dealer for more diagnosis.
There are many causes for this DTC. The troubleshooting must be performed accurately for a complete diagnosis.
Old May 2, 2005 | 04:03 PM
hoomza444's Avatar
is this a common problem on the s2k? i got the same code and will be seeing the dealer about it soon...
Old May 2, 2005 | 07:08 PM
Slows2k's Avatar
No, it's not that common.
Old May 3, 2005 | 03:45 AM
hondamanwill's Avatar
PROBABLE CAUSE
The EVAP bypass solenoid valve can fail due to
corrosion. The solenoid valve may get water inside. If
the water contains road salt, the solenoid windings
could corrode, causing the valve to fail. In a few rare
instances, the corrosion could be severe enough to
cause an internal short in the solenoid valve, which
could damage the ECM/PCM. If this happens, both the
bypass solenoid valve and the ECM/PCM would need
to be replaced.
Vehicles driven in the Northeastern part of the U.S. are
more likely to have this problem because of the salting
of roads during the winter months. Vehicles driven
where salt is not used on the roads are much less likely
to have this problem.
Old May 3, 2005 | 04:06 AM
Slows2k's Avatar
There are other causes ( damaged hoses, leaking o-rings) besides a corroded Bypass solenoid, A new one may not fix the problem.
Old May 3, 2005 | 10:32 AM
Empedocles99's Avatar
I had this one too! They had to replace a valve. Happened pretty much the day after I drove the car off the lot.
- Chris
Phantom327
Apr 13, 2017 11:11 AM
codyh
Jul 23, 2012 03:41 AM
dbchang
Jul 2, 2012 11:21 AM
jrb
Aug 1, 2006 09:07 PM
cthree
S2000 Service Bulletins (TSB)
Mar 12, 2005 09:57 AM
