Check Engine EPS
Old May 25, 2008 | 11:45 AM
mrscbw's Avatar
Default Check Engine EPS
Wats going on..First post here hope im in the right section... I was driving yesterday and I was going about 65-70mph I hit a bump not a big bump just a everyday one you hit on freeway..All of the sudden the Stereo cut out the check engine light came on and EPS..I lost my power steering..Idling alil lower then usual..Mileage no longer clocking.. And mph is stuck at 0...I'm at work didn't get a chacn eto get the CEL code yet. But it is a 02 S2000 and any ideas what might of happened? IM using ricks 4.57 gears i'm not sure if therse a speed calibrator on my car..If there is one wher eis it located? also where is the OBD port?
Thanks in advance..Worried =[
Old May 25, 2008 | 11:50 AM
SOHCmyDOHC's Avatar
you might have a calibrator. It probably died.
Old May 25, 2008 | 11:53 AM
Stratocaster's Avatar
The power was lost for the speedo calibrator. so take a look at some of the threads on how to install it and back trace the wiring to see if the power lead is still connected. The stereo is thestrange part, but I bet they have a common 12+ connection.
Old May 25, 2008 | 12:46 PM
mrscbw's Avatar
Where would the calibrator be located? I just did an EPS OTC Check adn it came out to be 22-1 VSS FAilure. Any idea where to start?
Old May 25, 2008 | 06:47 PM
You will have to read the referanced threads. I would guess it is by the EUC, behind the kick panel.
Old May 25, 2008 | 07:05 PM
negcamber's Avatar
Here are some instructions on Modifry's calibrator:
http://modifry.com/products/yj/Yellow%20Ja...202006-2007.pdf
Old May 25, 2008 | 08:12 PM
mrscbw's Avatar
So i finally had a chance to check under the dash and i found the yellowbox by ricks. The power was not lightning up so i checked the fuse..what do you know...the fuse was blown..10amp acc fuse. So i replaced the fuse and then radio turned on, so did the yellowbox...i treid to accelerate alil bit speedometer was still 0 and mileage still didnt clock EPS and check engine still on and it started smoking and a few seconds later fused popped again. im guessing i got a short somewhere..or could it be something else? would it happen to be where the smoke came out from? or could it be anywhere? smoke came from alil west of where the fusebox was (driver left leg kick panel).
Old May 26, 2008 | 07:44 AM
thrshr01's Avatar
That smoke is bad, sounds like a good size short. I'd recommend disconnecting your batter and look for open wires connections where the smoke is coming from. Don't put another fuse in there until you find the short.
Old May 26, 2008 | 08:36 AM
mrscbw's Avatar
Alright, I ran an EPS diagnostic and it said it had an open circuit in the EPS line. Any idea where the EPS wire is? IM thinknig thats the culprit. Also i jus tnoticed today that my vtec was not engaging either..Seems pretty bad..
Old May 26, 2008 | 09:27 AM
The YB is in the VSS Line. So if the YB is powered off, the VSS line is open. This is enough of a problem to cause you Vtec issue too.
Sounds to me that the way the car is wired is suspect. The YB and radio should be of differant circuits.
So you need to trace the connections. You can remove the YB from the car and reconnect the VSS wire. the YB only has 4 wires. 12+, Ground, Signal In and Signal Out. Trace them and remove the 12+ and Ground connections. Then reconnect the other two wires connected to the Signal in/out on the fatory harness.
Next, disconnect your radio. I personally would remove it from the car and look at thge wiring job the installer did. That may be where the root cause of your problem is.
